Results 1 to 15 of 23
    Sep 2005
    McHenry, IL
    222
    Thumbs up New Grizzly G9742 Band Saw
    I received my new Grizzly G9742 band saw last Friday and finally completed its assembly last night. I thought I would post a few of my thoughts regarding its fit and finish prior to any use.
    1. The base went together easily and was very straight forward. When I placed the saw portion on the base was where I ran into a slight issue. The bolt holes in the base did not quite align with the holes in the saw's casting. Two quik-grip clamps resolved the issue and all went smoothly from there.
    2. The motor shut-off seems erratic. I have spent about an hour or so trying to adjust so that it shuts off when a cut is completed and thus far have not gotten it to function to my liking. I will report further on this once I have a chance to use the saw.
    3. The indicator for setting the angle obscures the graduations on the scale when the scale is viewed from above. I am not certain why it was designed the way it was (as a pointer) but I will fabricate a replacement (it will have a relief either in the center kind of like a rectangles with a "V" shaped cut-out or a straight edge that will not obscure the scale)when I have a chance.
    4. One thing that I noticed about the head. When it is swung forward the left side can contact the bed. I am not certain how this forward swing is to be used as a result of this but time will tell. So long as I have the 45* rotation to the back I'm happy.
    Thus far I am very impressed with what can be had for $450. The machined surfaces looked nice and the head swings very smoothly. I will be purchasing a bi-metal blade in the very near future and then will really start cutting some stock. I will report further once I have some cutting time on the saw.
    SolidWorks Premium
    SolidWorks Simulation Pro
    MM210 w/3035
    DG Piranha II
    Sharpie Deluxe
    Stars & Stripes BWE
    Blue Optrel Satellite
    Northern Nevada
    740
    "4. One thing that I noticed about the head. When it is swung forward the left side can contact the bed. I am not certain how this forward swing is to be used as a result of this but time will tell. So long as I have the 45* rotation to the back I'm happy."
    You unbolt the vise and move it over, there are tapped holes for this, be mindful of filling these holes with chips.
    S.E. Wisconsin
    4,551
    Quote Originally Posted by katiebo View Post
    3. The indicator for setting the angle obscures the graduations on the scale when the scale is viewed from above. but I will fabricate a replacement (it will have a relief either in the center kind of like a rectangles with a "V" shaped cut-out or a straight edge that will not obscure the scale)when I have a chance.
    Thus far I am very impressed with what can be had for $450. .
    you're a patient man ......... for that price I would be Pissed (inexcussable for new)
    Phil J.
    Sep 2005
    McHenry, IL
    222
    Planet X,
    Thanks, I see it now.
    Vicegrip,
    I can certainly understand why one would think the way you do. However, whenever multiple pieces of sheet metal are used to form anything, my experience tells me all bets are off. In the world of metal working, as you well know, if there are multiple pieces that need to go together, and all the holes are to be precisely located then the holes need to be put into the assembly. Also, I have seen much worse craftsmanship from products that cost significantly more.
    SolidWorks Premium
    MM210 w/3035
    DG Piranha II
    Sharpie Deluxe
    Stars & Stripes BWE
    Northern Nevada
    740
    You are welcome.
    Another thing to watch out for is the bolt that tensions the motor, the stamped sheetmetal motor base is flimsy. Easiest workaround is to tension the belts by pushing by hand on motor and using a stop nut on that bolt. By doing this all the bolt has to do is hold the motor at that position it does not do any lifting.
    Better fix would be to fabricate a new motor mounting plate out've thicker material IMO.
    Albuquerque, NM
    4,986
    Cool deal, let us know how it works after you get around to cutting something ... I am still bouncing between the Grizzley and the Jet version.
    Regards, George
    Sep 2005
    McHenry, IL
    222
    If I recall correctly it is made in Tiawan.
    SolidWorks Premium
    MM210 w/3035
    DG Piranha II
    Sharpie Deluxe
    Stars & Stripes BWE
    Rockville, MD
    122
    Thumbs up
    Post some pics!
    Hobart Handler 140
    Hobart auto-darkening hood
    Craftsman 180 Amp AC Buzz box (late 60's?)
    Craftsman 2HP 20 gal air compressor
    Craftsman 12 inch band saw w/speed reducer
    HF green 4 x 6 band saw
    HF 12 speed drill press (mid 80's Tiwanees )
    10 x 20 shop
    “Failure is only the opportunity to begin again intelligently”
    Henry Ford
    S.E. Wisconsin
    4,551
    Quote Originally Posted by Sundown View Post
    Sundown , at-least check Ebay > Craiglist etc. ....for a Real saw that could be close enough for pick-up .
    I realize many of you are skilled hobby-ests , trust me .....a used industrial saw will cut like that Cooper of your's handels
    Katiebo : I'm certain you have all the abillity to improve your saw , and that's a GOOD thing .....but like the saying goes if a thing is worth do'n , it's worth do'n right
    it could have just as well been built well in the first place!
    Northern Nevada
    740
    Quote Originally Posted by vicegrip View Post
    What do you mean when you say "Real" saw Vicegrip?
    Central Kali
    5,292
    Talking
    It probably needs to weigh at least 500 pounds.
    S.E. Wisconsin
    4,551
    Quote Originally Posted by Planet X View Post
    like this >>>>OOPS only 400 lbs.<<<<LoL
    http://cgi.ebay.com/BAND-SAW-KALAMAZ...QQcmdZViewItem
    or at least like this
    http://cgi.ebay.com/HORIZONTAL-VERTI...QQcmdZViewItem
    or the ULTIMATE home shop ONE-Machine does it ALL
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=002
    Sep 2005
    McHenry, IL
    222
    real saw + mitering capability = very expensive
    I have already done the math!
    SolidWorks Premium
    MM210 w/3035
    DG Piranha II
    Sharpie Deluxe
    Stars & Stripes BWE
    Northern Nevada
    740
    Vicegrip checked out your links and thanks for replying.
    Katiebo, are you planning on fabricating in-feed and out-feed tables?
    I never got around to doing it for that saw, but should have and I am currently revamping something for my current saw. Anyway that mitering saw you have is an excellent upgrade over the standard 4x6 saw, which is excellent in its own right for the home fabricator.
    Sep 2005
    McHenry, IL
    222
    Planet X,
    I am going to start with work supports for now, as they are excellent multi-taskers. If I find myself needing dedicated infeed and outfeed support I will fab my own.
    SolidWorks Premium
    MM210 w/3035
    DG Piranha II
    Sharpie Deluxe
    Stars & Stripes BWE
