hi,
Ive been searching for a metal shear that can cut through thicker stuff like 1/8" stuff. Is there any kinda shear that will work with a hydraulic press? Thanks
hi,
HH 180, TA 185
once you start getting past 16 gage , the amount of pressure required to get the sheet to part is high enough that there is considerable shock in the machine in use , sheers that get past this do so by increasing the sheer angle , and so also the amount of deformation , and the tendancy for the cut to curl away from the stationary blade ...hence hold-down pressure rises as well ......for homeshop cutting I recomend ....as many of the following you can afford saws-all , plasma-cutter , vertical-bandsaw ( you can use a dull fine-tooth blade running upsidedown as a friction-saw) , chop-saw , powerhacksaw etc.
sort-of a Harrum for the cutting lust of the ocasion ....
Dont forget the old school "hand operated" and "arm powered" hack saw.![]()
HH187, TA 185 AC/DC Arcmaster, Hypertherm Powermax 380 Plasma
Smithy 1220 LX Lathe
Peter Wright 132 (198lbs) anvil
Hoods: Jackson Nexgen and Hobart/Miller XLi
Victor compatible med duty OA setup
Chop Saw, 4x6 Band Saw
In a portable, hand-held shear, the Trumpf 500-6 has 1/8" capacity in mild steel: http://robertstool.com:8091/index.pl/tru
Other hand-held shears are available at similar prices through most industrial suppliers.
Barry Milton
____________________________
HTP Invertig 201
HTP MIG2400
Clarke Hotshot
I've used a beverly B-2 on 1/8. I wouldn't want to do very much but it worked. I'm sure the B-3 would be better.
MM250
TB250g
22A feeder
Lincoln ac/dc 225
Victor o/a
Lincoln square wave 175
MM180
SP125+
