Results 1 to 15 of 19
Thread: Hard Face Or Ss
    Jun 2006
    Wichita, KS, USA
    4,102
    Hard Face Or Ss
    I was talking to somebody the other day about wanting to put some hard-facing on the homemade blades of my homemade shear. They mentioned that the weldors they knew were getting away from hard-facing, unless it was spec'd, and just using stainless rod. Does anybody know of this? Would this work for my shear? It doesn't see much other than Al and brass, but it would be nice if I could cut mild steel and even nicer if it would cut stainless.
    MM180
    SP125+
    Nov 2006
    Colorado
    105
    ya know this just My opinion for what it is worth but personally I would go for the hard face .....granted SS is good for some abrasion ....but good ole hard face is definately hard to beat......after all that is what it was made for ya know..hence the name ...."hard face".
    again tho it is just My opinion
    Hobart Champion 10,000
    Miller S32P Super
    PowCon 400SM
    Hobart Handler 120 CV
    Hobart stick mate 230 AC
    Harris torches
    Jet grinders
    Chevy Trucks
    May 2004
    canada
    101
    Use hardface. I really don't know how anyone would ever come to the conclusion that stainless is hard and could be substituted for hardface rods on equipment that needs to be hard and to hold an edge. Stainless is soft. Although there is a couple kinds of stainless filler for the hardenable 410 stainless and such. It would probably cost more then normal hardface rod and still not have the same properties.
    S.E. Wisconsin
    4,541
    post a pic of the blade you have .......likely much easier to make a new one ......if you can't heat-treat it .....send it to me ...and I will
    Aug 2006
    546
    I'd definately go hard face.
    I just bought a re supply for my shop.
    I have used it. I like it. It has its' place. Sounds like your job is one of them.
    IMHO.
    Good luck!
    Hobart StickMate LX 235 AC/DC
    Hobart Handler 125 EZ
    Hobart Handler 187
    Champion 4500
    Mag-Power MP 55 Plasma
    Lincoln Precision TIG 185
    Smith O/A
    Clarke 95e
    S.E. Wisconsin
    4,541
    or have the blades you have Ion nitried??
    Jun 2006
    Wichita, KS, USA
    4,102
    Here's a pic of the shear. Keep in mind it was originally done to cut aluminum, which it does great. It is all mild steel that I had laying around, so it was cheap. Ideally, it would be great if it could cut 17ga 304SS, but that might be a bit optimistic, even with the right blades. What do you think?
    MM180
    SP125+
    Aug 2006
    546
    Whateg0:
    Nice. Good use of spare parts!
    17g may be a bit optomistic. Hard to tell from the pic as I can't really judge scale. The vice grips help a bit. You may be able to swing 17g.
    I'd definately stick with hard facing.
    Hobart Handler 187
    Champion 4500
    Smith O/A
    Clarke 95e
    Jun 2005
    Michigan
    807
    I saw a cheap way to case harden mild steel the other day, though I don't know if it would be as good of a choice as hardfacing. Heat the whole piece in a forge or a hot BBQ grill to a red heat and quench it in used motor oil. (FIRE!!! lol) The high carbon content of the oil will soak into the mild steel as it cools. Repeat for deeper treatments.
    Like I said. It may not be a good choice for this application. Might not even work as described. May even be a bad idea. Who knows? But I think I remember reading in another thread that you had a small forge and it sounded like fun. So I thought I would share it with you.
    HH187, TA 185 AC/DC Arcmaster, Hypertherm Powermax 380 Plasma
    Smithy 1220 LX Lathe
    Peter Wright 132 (198lbs) anvil
    Hoods: Jackson Nexgen and Hobart/Miller XLi
    Victor compatible med duty OA setup
    Chop Saw, 4x6 Band Saw
    Jun 2006
    Wichita, KS, USA
    4,102
    Dave,
    I don't actually have a forge; just a small furnace, but I could use the burner to heat it up. It does make lots of heat. I guess I will just try the hardfacing. I think the next question is, do I have enough welder to do it (85A)? Or do I need to use Dad's red tombstone? (I am thinking mine won't do it.)
    The bottom blade, for reference is 1/4" thick and the upper is 3/8".
    Thanks.
    MM180
    SP125+
    S.E. Wisconsin
    4,541
    Quote Originally Posted by BillDaCatt View Post
    Trust me these are a simple parts to remake ....unless you blow-off the whole cutting edge , your results will be OK at best ! you could maybe do (??? tig filler , sorry don't know the name :gives 54-56 / RC i think but your edges will have deformed by then ....one blade will have to be ground to the other.....just find a couple of chunks of A2 or S7 or D2 ....Ican H. T. for less than Culver's for the Familly
    Northern Cali
    182
    BillDaCat did you see that on the latest mythbusters?
    Hobart Handler 175 Mig
    RIGID 14" Chop Saw
    DeWalt 4 1/2" DW402 Angle Grinder
    MI
    1,012
    I thought mild steel was not heat treatable. I was under the impression that the oil simply disssapated heat much faster than water, so it was used. Also leaves a finish on the steel indicating this process was performed on it. Anyone?
    May 2004
    canada
    101
    Low carbon steel can be case hardened. It takes hours and some proper equipment to get good results. Casenite is normaly used. I've made shears before for special jobs. I used mild steel for the construction with machined pockets for the knifes that I made out of tool steel which I hardened and ground. Tool steel isn't that expensive, even using something as simple s 1080 will make all the difference in the world compared to 1020.
    Heating low carbon steel and dipping it in oil or water will do nothing good. It won't harden it. It will make it more brittle, it lowers its flexibility. Along with other things, there's a lot involved in the molecular structure of materials and their reaction to different heat threatments. I won't pretend to know it all. I do know that this is why you don't quench a test plate before doing a bend test.
    Jun 2005
    Michigan
    807
    Quote Originally Posted by wworks View Post
    Yup! I also read an article in the past week (that I can't find at the moment) explaining how to do it with a case hardening compound.
    SND kind of confirmed my suspicions. It's much harder to do well, than it is to do poorly. Nice to know it can be done at all though.
