Results 1 to 15 of 16
    Jan 2005
    Minneapolis, MN
    96
    Drilling into tubing
    I need to dill 3 1 5/8 holes into a 2 1/4 16ga SS tubing. What would be the best way to drill these holes? I was thinking using a tubing notcher and a 1 5/8 hole saw, but most tubing notcher's only accept 2" tubing. I don't have a drill press, just a drill and these holes have to be perfectly aligned. This is for a log type manifold. Any help would be really appreciated.
    Rutedog <---DISPLACED TEXAN
    Thermal Arc 185
    Lincoln SP-175 Plus
    Jet Bandsaw
    Milwaukee Chopsaw
    Jun 2006
    Long Island NY
    107
    Hmmm...
    Without at least a drill press using that hole saw it's gonna be tough. Especially since it's light gauge and stainless has a tendency to work harden. Hole saws will guide themselves once they get going but, they make a sloppy hole. That tube notcher would be nice if you could fit it, which you say it can't. What might be easiest is to trace out the hole you need (notch a piece of 1-5/8 tube with a 2-1/4 hole saw and use that to make your trace against the 2-1/4 tube) then drill a large pilot hole (unibits work exremely well) and finish up with a carbide burr out to the trace line.
    I can't see any way to do that by hand and get the hole dead square with the tube. I'd hire it out.
    Jun 2006
    Long Island NY
    107
    What's...
    the manifold gonna be for? Just curious...
    Mar 2006
    467
    Hole saws generally bore a hole 1 size larger then the marked size so a 1 1/2 cutter would be better.
    If the holes are 90* to the tube a notcher won't help. Clamp it into a drill press and go from there.
    Or send it to a machine shop, this isn't much of a problem on a vert mill. Make sure you give them accurate measurements otherwise you will end up with a wrong part built to your drawing. Sending a gasket and flange for checking would be a good idea too. Tell them it is for a exhaust manifold and discuss the tollerences. Stating the holes must be exactly 1 5/8 (1.625 ) and having the part come back 1.625 + - .0001 will cost you much more $ for no gain.
    Jan 2005
    Minneapolis, MN
    96
    I think I'll be getting me a drill press .
    Richs,
    It for a turbo project. Going to boost a non-aspirated car.
    Thanks for the feedback guys.
    Thermal Arc 185
    Lincoln SP-175 Plus
    Jet Bandsaw
    Milwaukee Chopsaw
    Mar 2006
    467
    Some sort of V6? Or puting a turbo on a Sprint 3 cyl?
    Jan 2005
    Minneapolis, MN
    96
    Masher,
    I'll make sure to get a 1 1/2 cutter instead of the 1 5/8. Thanks for the heads up.
    Thermal Arc 185
    Lincoln SP-175 Plus
    Jet Bandsaw
    Milwaukee Chopsaw
    Jan 2005
    Minneapolis, MN
    96
    V6 3800 Series II
    Thermal Arc 185
    Lincoln SP-175 Plus
    Jet Bandsaw
    Milwaukee Chopsaw
    Clark County, NV
    5,078
    Quote Originally Posted by Rutedog
    Does it have warp drive? Or did you mean naturally aspirated?
    Jan 2005
    Minneapolis, MN
    96
    OOOPS!
    Yeah, I meant naturally aspirated.
    Thermal Arc 185
    Lincoln SP-175 Plus
    Jet Bandsaw
    Milwaukee Chopsaw
    Quote Originally Posted by Masher Mfg
    My Lenox hole saw kit cuts a hole the same size as the OD of the cutter. When you say "one size", do you mean by the sixteenth, or what?
    Sacramento, CA
    631
    Hank, Ive heard you always buy the size down from whatever size you really want, as they are never perfectly true and spind out of round sometimes. Ive always interpreted it as whatever the next size down is on the shelf...thats what you buy. Im with you though...Ive always drilled the hole with the exact size I needed...but I have heard this elsewhere as well.
    Kyle
    "The Young One"
    Owner/Founder of CCF - Curleys Custom Fabrication
    Jan 2005
    Minneapolis, MN
    96
    I'll pick up both sizes. I'll start with a 1 1/2 and see how that goes.
    Off Topic
    BlueOval,
    I was in Sacramento last weekend and the heat you have to put up with is insane. I think it was 109 and I was there for an outside wedding .
    Thermal Arc 185
    Lincoln SP-175 Plus
    Jet Bandsaw
    Milwaukee Chopsaw
    OK.
    I went out and grabbed a 1-3/8" unsused Lenox hole saw. Measured with a dial caliper, it reads 1.380 on the outside of the tooth cast. That seems like 1-3/8" to me. A "size" (32nd? 16th? 8th") either way would seem to be a big mistake in labeling. I never cut door hardware in 37 years with an under or oversized hole saw. If it's a 2-1/4" hole, I used a 2-1/4" hole saw!
    Lo siento mucho, y buenos noches.
