Here is the frame, complete except for the axle, coupler and a few minor details. I will post more pics as the project moves along.
________
Suzuki GN125E
________
Suzuki GN125E
Jason, looks like you have a good start. Keep the pics coming. I need to get around to mine sooner or later.
Bob![]()
Looks good. When I built my trailer I put the cross members under the top rail. I also extended out the middle cross members to attach my fenders to. Be sure to have a 60/40 ratio in your axle placement. I went 50/50 at first. It was kind of squirelly. I ended up cutting some off the back for a better ratio. I hope you are using a 220v welder to do this.
Art is dangerous!
www.PiedmontIronworks.com
Yea, when I get the axle (hopefully this afternoon) I will put it in 60/40. I am using the MM210 for almost everything, I did have to use the Lincoln for two stick welds where the A-frame members meet the side members there was no room for the MIG. Both machines are 230 volt.
Here are some more pictures.
This is my sandwich gusset.
________
Honda ST1300
Here is a picture of the corner detail.
________
easy vape
Just a picture of a weld.
________
buy vaporizers
JASON........NICE JOB...........HOW MUCH WEIGHT IS THIS BABY GOING TO CARRY FOR CAPACITY..........ROCK..............![]()
SSCOTT@MILLERWELDS.COM
Good looking job. Jason. As an aside, if you ever need to, you can increase the strength by running another length of tubing, on top of, or underneath your first one, and by doing so increase the strength by a factor of 4 not just two.![]()
Arcin' and sparkin', Rocky D <><![]()
Thanks guys! Everything is working out really well so far, that's where a little extra time planning pays off. The axle is a Dexter Torflex rated at 3500 lbs. The trailer is going to weigh about 600 lbs. or so, so 2900 lbs. of cargo.
Rocky, that's a good idea. I will keep it in mind for the next one (I will be building a flatbed sometime after this one is done).
Well, I picked up the axle this afternoon, along with all the other parts EXCEPT the axle mounting brackets! They are back ordered 'til the week after next so I guess it's on hold for a while.
Jason
________
Yamaha FZ750
Well, I couldn't wait two weeks for the axle brackets (and my wife couldn't wait to start parking in the garage again) so I made some.
________
vaporizers
And now the trailer is rolling. After I get a coat of paint on the frame, the next phase will be the walls.
________
silversurfer reviews
Looks good. What type sides/floor are you planning to use? Can't wait to see the finished product.
Cope, thanks, the walls will be framed with 1 1/2" x 1 1/2" 14 ga. tubing. The skin will be .032" aluminum sheet. The inside of the walls will be covered with 1/4" plywood for shear strength. The floor will be 3/4" plywood.
Jason
________
Harley-Davidson Topper
Well, I finally got a chance to get back to the trailer so now the walls are up.
Here is a picture from the front.
Jason
________
RC165
And here is one from the rear.
Jason
________
Rehab Help
