I traded my SP-175 plus for a tapped Thermal-arc 181 the other day, and
was not happy with the 4 tap voltage. It's really high and worse if you have
high input voltage to start with. Anyway 3/16 steel was a mess that you
really could not adjust out. I really like how it welds on the lower taps and
prefer it over my last SP-175 plus by a mile. (My first SP-175 was nicer then
this last one)
Anyway this is a picture of what I did and a weld bead with the fix,
second one without. I did not change any settings between the two.
The one picture shows the coil of wire a bit better, but it was not the
final deal. Extra 25ft ground lead in the #1 pic.
You shouldn t need anything more then a short length of a 3/32 SS filler and that coil to get the output on that fourth tap to perform much better. If you're interested in giving this a try , I'll email you the set up instructions.
. Thank goodness my wife doesn t read this stuff, or she'd be given me a hard time all evening.
