    May 2006
    2
    Hobart Mega-mig 450
    anyone know where to get the information to wire it from 3phase to single phase?
    999
    This is a 3 PHASE machine only!
    May 2006
    2
    thank you, for the info, I'm gonna throw the at one on the truck and use it and I will just use the miller rig I rewired today for shop stuff,
    I got 5 welders given to me from a frend of mine who works in big corps on the equipment, gets alot of the used equipment and he gave me 4 Mig welders and 1 spot welder
    Sep 2005
    1,052
    wire feeder
    Howdy Howdy! I nead a Lincoln Wire feeder Or something that can run off of a Lincoln Invertec V-350 Pro Advanced process machine. Thanx! Brian Lee Sparkeee27
    999
    Any manufacturer of feeder will work off a 350pro, as you have 24 / 42 / & 115 vac available. The only minor hassle is that the Lincoln is looking for a simple "C" &"D" connection to power it up, so a Miller feeder requires an additional relay wired into it
    Miller sends back a control voltage, this voltage must be appled to a relay, (other side going to common or ground) with 2 of the Normally open contacts going back to "C" & "D" of the machine.
    Not a biggee, just email me with what ever feeder you decide on using.
