Can standard water pipe (black iron) be MIG welded?
Water Pipe from Home Depot etc.
Jeff Phillips
Silver Moon Forge
HH 180
Hammers and Anvil
Coal forge.
Other "stuff"
"Those who don't weld so good, become expert Grinders"
"Measure to build, Hammer to fit, Paint to hide."
I've never done it, but from what I've read, "Yes."Originally Posted by unkle spike
However, I've also heard reports that "home center" pipe may not be of the same quality as you'd get from a plumbing supply wholesaler or steel supply company ... so it may not have the same sort of yeild strength.
I'm sure that others with direct experience will chime in. (And I'll be watching, as I have a pipe bender and one of my next projects will be a set of racks for my F-150 4x4 pickup to carry long lengths of tubing, lumber, and (occasionally) my 14' 6" touring kayaks.)
Regards,
Carl
Reading books, watching here, and practicing to become proficient.
Dynasty 200DX w/ 120 and 80 cf Ar tanks
HH180 w/ 120 and 80cf C-25 tanks
AirForce 400 plasma cutter
Victor Super-Range II OA set w/cart and 80cf tanks
HF 14" chopsaw
Turn-Pro 3195 3-speed gearbox 7"x12" bandsaw
About 8 HF 4-1/2" angle grinders (I hate changing wheels![]()
Misc other shop tools
Oh no... not this one again... please read through these couple of threads before the "battle" starts again![]()
http://www.hobartwelders.com/mboard/...ead.php?t=8318
http://www.hobartwelders.com/mboard/...ad.php?t=18508
Hobart HH 125EZ
OH OH I started another stupid thread........
All I want to do is make a mailbox post out of something round, doesn't need to be DOM or anything.
I will try to weld it, experience and humiliation are teachers that are best kept seperated....
Jeff Phillips
Silver Moon Forge
HH 180
Hammers and Anvil
Coal forge.
Other "stuff"
TO put it easy Yes I can be welded. Clean it up a bit first. Wire wheel or grind off area that is to be welded. I have used "black Iron" gas pipe on a few things. A front bumper .. Made a hoop from the cross tubes ( 1/4 " thick X 3 1/2 OD Was part of a Over Head 10 Ton craine ) the hoop came up to the top of teh hood and back down. And I have used a bunch with solid bar stock to make large hinges.
OMS
HH175
Red Tomstone W/ HF for TIG
Old Miller Engine Driven 225 Amp AC Stick Welder
Smith O/A X 2
Harris O/A
BridgePort
MSC cut off BandSaw 6X12"
And more!
Shop Mechanic for Brinks Coin
I don't weld, but I looked into this before I bought some black iron pipe to fabricate some supports. It really is steel and calling it iron isn't quite accurate. It's usually ASTM A53 pipe and that ASTM grade is used for well casings here in Florida all the time. The casing joints are almost always welded. A friend welded up the supports using the pipe with no problems at all.
Uncle,Originally Posted by unkle spike
I have used the exact Pipe from Home Depot you speak of and it will weld up just fine for your application.
Carl,
If you get your needed stock from a real Pipe shop, you should be good to go. I think the horror stories of Rack Failures are more due to operator error than material failure![]()
MM252
MM211
SO 2020 Bender
A53 is welded every day. TIG, MIG, stick, whatever. It is meant to be welded.
Clean the joint area well (inside as well as outside) as for any weld, payig close attention to removing all of the coating from the pipe in the weld area. Bevel the edge if needed, and weld away.
The quality problems can show up in pipe purchased from ANY supplier. The pipe HD and the other box stores carry usually comes from a local supplier, but if you supply HD as well as commercial outfits, and you know that you have a lot of pipe that has been problematic for the shops that weld it, where will you send the rest of the lot? What are the problems? contamination in the stock metal (ony a sample of sticks are tested at the factory, so it happens that a bad run gets out), poor quality at the seam (incompete welds and contamination in the weld), and dimentional issues are the ones I have seen recently.
Should be perfect for me thenand dimentional issues are the ones I have seen recently.![]()
MM252
MM211
SO 2020 Bender
i weld black pipe with mig and stick all the time and never a problem. just wire wheel it clean were it is to be welded.
tc.....jim
miller bobcat 225
miller AEAD200LE with hf tig
mm175, mm252 w/30a
lincoln PT 225, mm211, TA181i
stickmate LX 235/160
Speedglas 9100X/9100XX/Miller DE
hypertherm 380
TD cutmaster 52
steel max 14" & evolution 7.5" dry cut saws
2 victor journeyman/3 superange, smith little, meco midget torches
ridgid chop saw
kalamazoo band saw/ 8-4.5" & 1 rockwell 9" grinder
case 580 backhoe for things i can't lift![]()
if at first you don't succeed
trash the b#####d (me)
Originally Posted by enlpck
Any suggested starting settings with an HH140 using flux, for example?
The Chart in your manual will get you in the Ball Park
.030 3/40 1/8"
.030 3/45 3/16"
MM252
MM211
SO 2020 Bender
