Results 1 to 11 of 11
    Mar 2006
    Texas
    155
    Question Lumber rack, need suggestions...
    My next door neighbor wants me to weld him up a lumber rack for his barn. Largest wood he will stack on there will be a few 1x12's but mostly 2x4's, 1x4's, maybe some rebar, or a pipe here and there.
    The design is an A-Frame like a swingset with 1 foot wide shelves. He wants to go as economical as possible. The A frame will be 6 foot tall with 4 shelves. I will be welding it up with my Lincoln 125/225 ac/dc stick welder.
    What would be best? I was thinking 1/'8" square tube. But what size? 1"? 1.5"? Or go to a thinner 14 ga 2" sq tube?
    I don't have a pipe jig to fishmouth pipe was why I was thinking sq tube.
    Looking for medium strength.
    Any suggestions on what to make it out of?
    You hammer the iron that lay on your anvil, instead of daydreaming of working silver.
    Jun 2003
    181
    Quote Originally Posted by chabat
    Well, um...............this probably isn't what you want to hear.............but a good way to do this ON THE CHEAP is cut a truck frame in two...........I guess that's assuming you've got a couple lying around - I do. I'd ship ya one but it might be a bit expensive Oh, and the other one in the yard is spoken for by the wife - she wants to turn it into a bookcase downstairs - no joke.
    Ignore the ugliness, you could make it more aesthetically pleasing. Oh, for a moment she thought this one was a jungle gym, it certainly looks better when she's in the picture
    Mar 2006
    Texas
    155
    Wow, umm, great idea! But I don't have a truck frame. That pic of the girl is funny.
    Anyone else have a suggestion?
    We planned on buying steel, just trying not to overbuild to keep costs down...
    Los Angeles
    5,475
    Same A-Frame idea just use Angle iron, like in this pic but made to your size. I had 2 of these at a Studio I worked at and we loaded them up with Steel Pipe and AL Tubing.
    MM252
    MM211
    SO 2020 Bender
    Mar 2006
    Texas
    155
    Did you build that Broccoli?
    What size/thickness of angle did you use?
    Los Angeles
    5,475
    No. It was cheaper to just order them and they just bolted together- and I wasn't going to get paid by the Company to make them.
    I believe 1"x1"x 1/8" Angle
    Worked good though.
    MM252
    MM211
    SO 2020 Bender
    Mar 2006
    Texas
    155
    Broccoli, that rack looks awfully narrow, what were you putting on it?
    Mar 2006
    Texas
    155
    I came across a similar design Broccoli. I may just copy this... Northern Tool Item #97220-1605. It says it can support 2k pounds and it is 14 guage...
    Los Angeles
    5,475
    That's what I had in mind for what you wanted to build-
    The ones we had were narrow but we used both side by side and we were stacking 1-1/2"x10,12' AL pipe, steel pipe and some 1"x1"x 6' AL Sq. Tubing.
    MM252
    MM211
    SO 2020 Bender
    forsyth, ga
    318
    for only $109 when you figure material time and resources, your gonna have a hard time beating it, that is unless you just want to do it, or you need a new tool for it , or some other worthy reason.
    Mar 2006
    Texas
    155
    I know, $109 ain't bad, but we are bartering. I help him with welding, he will build a mini mx track for m with his tractor...
    Bartering is a great thing. My brother is the master of barter, I should learn a few things from him.
