Results 1 to 2 of 2
Thread: my welds
    Northern Cali
    182
    my welds
    here are some welds that i made today. Its on 1/8" wall 1.5X1.5 square tube. using HH 175 wit .035 lincoln flux core wire. any pointers?
    Hobart Handler 175 Mig
    RIGID 14" Chop Saw
    DeWalt 4 1/2" DW402 Angle Grinder
    Sep 2005
    Davenport, Iowa
    824
    Well the first three pics are of the same weld and it could use a more consistant travel rate. You need to let your puddle build a little more at the start and move a little faster where it got fat in the middle.The second weld looked like you didn't clean the material.No matter what anyone says, welding likes clean. The less contamanites(sp?)you introduce into the mix, the better.
