I have a rear blade that hooks to the 3 point hitch on my tractor that is cracked at the mounting bracket which is 1/4". My question is do I just "V" the crack then fill it in? I have been told that I should drill holes at each end of the crack then V. Also how wide should I weld the area aound the crack on the mounting bracket? Thanks in advance, this is a great forum!
) of custom farm fabrication and repair experience...Generally if the crack is in mild steel drilling holes isn't required, however, you need to find where the crack begins and ends by griding your "V" futher past it's visible edges. I usually "V" out almost the full thinkness and run my first root pass, then crank up my machine for a HOT pass just to set everything in. Then, if needed, turn the machine to normal settings and continue to fill. I would also add that 99% of my work was done on a Miller 250 MIG. When done correctly and with correct fabrication techiques MIG will give you plenty of strength for the application.
