Originally Posted by
New2theArc
Thank you for all the tips, I went and bought a new liner for my gun, that helped but didn't solve the problem. I am finding tonight that when I am welding the arc comes back up into the tip and has been leaving a little ball of weld on the end of the tip I figure this is causing it to happen more frequently so when ever it happens once I check the tip it isn't always there. I have had to change my tips more tonight due to this little ball of weld at the end cause when I pick it off sometimes a little bit of the tip comes with it. Also when the wire starts to come back up to the tip it will leave some searious undercut. I am not a great welder and leave undercut at times but never like this or as much and often as this. I am getting very confused and frustrated with this as nonthing seems to be working. GOD help me tonight.
What happens if you cut back to short-arc? Hook up some C-25 or CO2, or just try it with the 6%, and see if it'll run OK in short arc. It still sounds like wire feed trouble. If I get a burnback all the way to the tip in spray with the MM210 (not nearly as robust as what you have) it's because I got too close, or I'm not feeding wire fast enough. I dunno, maybe try some .030 wire? But, .035 should spray fine with those parameters.
