At 51 years of age and two very active sons, 16 and 12, requires staying just fit enough so that I can keep the illusion ( in my mind ) that I can still whoop their asses when required. ( probably not true in reality). My cluttered basement contains some ( not used enough ) pretty good fitness equipment, thanks to a brother-in-law who sells the stuff. The olympic weight plates needed to get off the floor to make room for getting back into working out. So, over the last two nights, I threw together a weight tree made from some scrap 12ga uni-strut and 1 1/4 sched 40 steel pipe. I used my Pro Mig 175 with C25 and .030 Lincoln ER70S-6 wire.
Supposedly, uni-strut is mild steel but I don't really know what the composition is. It seems to spatter a bit more than usual when MIGing it. Here are some pics. The two pics of beads don't really show the spatter but, trust me, my helmets protective lens and shop floor show it.
The tree
The tree with weights
A bead pic
Another bead pic
