Results 1 to 15 of 15
    Dec 2005
    48
    using clother hanger for filler rod
    are clothes hangers any good for filler rod? I was practicing with them when i had my scratch start machine, but are they good for anything else?
    Central Kali
    5,292
    They are real good for hanging clothes.
    Oct 2005
    Mpls, MN
    1,195
    It's myriad orders of magnitude more cost effective to spend the $2/lb and buy appropriate tig filler rod that's already straight and the correct gauge for the job you're doing than stealing hangers from the closet or the dry cleaning.
    Dec 2005
    48
    we were actually just throwing them out today and i figured they would be ok to practice with.
    enlpck is offline teacher student weldicatr
    Oct 2003
    nj
    2,245
    Biggest problem with hangers is coatings on the wire. Straightening them is annoying, but removing the coating is a real pain. And, you don't know what the material is. Some are a high quality steel wire, others are garbage. None have the desirable alloying elements for filler wire (to keep the weld metal ductile, deoxidizers in the proper amount, etc)
    Jan 2006
    Tennessee
    1,166
    I have used them on several projects. The welds haven't failed and some are under terrible stress. They are a last resort for when you don't have any of the proper rod available. IMHO
    Mar 2005
    Lafayette, La
    560
    If your stranded on an island 5000 miles from nowhere, OK
    Otherwise, use some store bought tig rod. $15. worth of filler and you can practice till your arms fall off. Don't bother with coat hangers.
    You can make your own toothpicks too. Don't know anyone who does though.
    Jan 2004
    Browns Valley, CA
    8,518
    Wannabee,
    Do yourself a favor and don't start off on the wrong foot. If you happend on some wire coathangers from 30 years ago, they may be useful, but the wire coat hanger of today is nothing like the old ones. They are LOUSY filler metal. I'd use one on an emergency, non-critical weld if it was all I had, but it would be a stretch.
    Filler is pretty cheap, especially ER70S-2 for TIG - around $2/lb.
    ...from the Gadget Garage
    MM 210 w/3035, BWE
    HH 210 w/DP 3035
    TA185TSW
    Dec 2005
    48
    yeah dude, they are old school. They are real stiff. I dont plan on doing anything structural with them only practice.
    Dec 2005
    48
    when I do start building my manifold would you reccomend ER70S-2?
    Sep 2003
    Clark County, NV
    5,078
    Assuming mild steel, yes. Or S-6.
    Dec 2004
    Killingworth,Ct.
    1,266
    To Hank
    Quote Originally Posted by hankj
    Wannabee,
    Hi There!!!!My first dune buggy i built when i was 16 i gas welded with coat hangers,,,,wouldnt do it today,,but it was still on the road 10 years ago,,when i built the new house,Almost time?????????Remember Pal,,,its 5 oclock some where Jack
    Sep 2004
    Reno Nevada
    200
    Quote Originally Posted by wannabee welder
    "DUDE" Geese I hate that term.........Guess I'm showin my age!
    Nov 2005
    Raytown,Missouri
    37
    coat hangers for welding
    naw don't use them for welding,cuz then you don't anylace to hang yer clothes(tee hee).back wwwwwwwway back when probably when alot of of the welders that visit here were small children,welding(gas welding could be done to some degree of success with coat hanger but even then it was real" low budget")please do not go therenot evrn with practice ,it's a waste of time AND gas ,BUT keep on weldin,you'll get there :
    Nov 2005
    Raytown,Missouri
    37
    Oh yeah ,I forgot to mention just get the right filler rod&then learn toweld with the right stuff CYA, RICK BEAVER
