Hi all,
I'm working on a project in which I need to weld some 16ga mild steel to aluminized exhaust pipe of about the same thickness. (Basically I'm welding some baffles inside the pipe - has nothing to do with exhaust other than that's the material I have.) Given that the pipe is aluminized (not aluminum!), should I use flux-core wire or will solid+gas work?
Gary
