Results 1 to 2 of 2
    Northeastern Oklahoma
    1,436
    Lincoln's STT wire feed
    Anybody familiar with Lincoln's STT. Vo-tech has a couple of them and thought I Might take one for a spin if I enroll in the upcoming MIG Class. Instructor says they are a bear to get the setting right but are very sweet once they are dialed in.
    Dennis
    Dennis
    Thermal Arc 185-TSW
    Millermatic Challenger 172
    VictorO/A
    Esab PCM-875
    Wholesale Tool Mill-Drill
    Canada
    369
    Hi Tailshaft, there are many types of STTs
    The stand alone units are the Invertec STT and STT II . These units can be hard to set up if you are not familiar with them. The best is figure out your application and call Lincoln. There is a ton of application data for these machines
    The reason STT is confusing is everything you know about MIG you might as well forget because it violates the most fundamental aspect of MIG:
    In MIG, Current varies with WFS - if you turn up the wire feed speed current goes up
    In STT ( not a CV or true CC machine ) your WFS is independant of current.
    This is why people get thrown for a loop with STT. They are use to WFS and Voltage ( as all other MIGs ) but now you have WFS, Background Amps, PEak Amps, and Tailout . There is NO voltage control
    Fortunately if your machine is a Power Wave 455 STT , the its way easier because the Power Wave is fully synergic. Once you tell the machine what material ( steel , stainless etc ), wire size, and gas it chooses all the others to put you in the ballpark
    The latest generation of Power Wave 455M / STT has synergic but oddly enough they ALSO have non-synergic . If the machines are these M models make sure you are not in the non-synergic modes.
    BTW , STT is the most amazing short arc you will ever use !
