Dose anyone have a 100 amp ArcOne tig/stick welder? I called the distributor and they said the machine is manufactured off-shore and they havn't had any compliants in two years since the switched manufacturers. They said the previous model...I guess the same amprere...was nothing but headaches. I guess it was unrealiable.
I have been looking for a TIG welder that would steel weld up to .062. I was looking to weld thin material and no alum. I already have a millermatic 175 mig welder that works great on the thicker material but I have some difficultly welder thin material. I wanted to void spending 1000 dolars on a TIG welder that is going to be used part-time.
Dose anyone have an Arcone tig/stick welder (100 amp) and if so what is your impression. Have you had any problem with it?
Ed
