I have a ranger 250 with an LN25 wire feeder (Guess I didnt need to repeat that huh?)
The problem is I am welding 1 7/8 OD x .065 Round Galvanized (Although it happened when I was welding bare 1/8" flat also) 20 volts 275 IPM .035 wire C25 gas
The arc burns up the wire so I have about 3/8 of an inch gap then it goes back to normal.
This happens about 3-4 seconds after initail arc is established. Good for 3-4 secons then it cycles back and forth. Of course I checked drive roller condition and tension. Checked to be sure the roll of wire was not tight and didnt have any crossing wire etc. Changed tips,
nozzle, roll of wire. I watched the roll of wire while someone else welded and the wire
"appears" to be feeding smoothly, couldnt see any variation in spool speed. Now I do have a 45 liner in the Magnum 300 mig gun but I always have had and this problem just started.
What about the work connection? My clamp doesnt fit over the 1 7/8 tube so I cut a small slice of the pipe and welded it to a vice grip type clamp so it would stay well on the round pipe and I connect my work clamp to the clamp on the pipe. Would a poor ground cause this problem though? I hope its something simple I'm not getting.
Thanks in advance,
Mark
