Page 1 of 11 1 2 3 ... LastLast
Results 1 to 15 of 158
    Aug 2005
    Somewhere in Virginia
    795
    Talking Shop Cabinets (Pics)
    HERE IS THE LINK TO THE PLANS FOR THESE CABINETS (Updated 04/07/08)
    http://reference.toolandfab.com/writ...nets/index.htm
    Any links to these plans found within this thread may have broken links, so please try the one above first!
    Cabinets in work:
    Scott
    Last edited by MXtras; 04-07-2008 at 08:31 AM. Reason: Added updated link to plans
    Aug 2005
    795
    Cabinets complete:
    Scott
    Aug 2005
    795
    And they go with this stuff:
    To look like this:
    Aug 2005
    795
    A few more of the others, in their temporary position:
    What in the HECK are those dots in my pics from??? Sometimes I get them, sometimes I don't.....
    Anyway - here is the semi-permanent layout. It will likely change, but for now it looks like it will work. There is a large cabinet (one of three that will be built) in place to separate welding from the other work area.
    That little lathe stand is next for the brushed aluminum panels and the drawer treatment.
    I am also working on a few more large storage cabinets and a few more tables.
    This is all stuff for my shop - MXtras. I will be making my product here instead of the house! I have been working on this shop everyday since January and started from nothing. I did the electrical (208V 3 phase) - yes it is to code. The Millers are single phase machines. The welding table weighs about 1200 pounds - it turned out OK, but the top is not as flat as I had hoped to make it - it varies by maybe 1/8" across the top surface (4' X 7') using a staight edge and my eyeballs. The 1/4" top puckered a little at every stitch - and the stitches are only 1" long and few and far between...
    The pics are of the back corner of the shop. The front half is way to messy to show.
    I still have a milling machine, a 5T arbor press and a bunch of little stuff to move in, and I have to build a long saw table for the miter saw to handle 25' long material. I think the saw table may have to wait for a while - I gotta get the milling machine CNC'd and get some parts and molds made.
    More stuff to come in a few weeks or months - depending on progress.
    Scott
    Central Kali
    5,292
    That is real nice work. How did you do the drawers and I don't quite understand the lathe stand. What size lathe is it?
    Jul 2005
    New Zealand
    344
    Outstanding!!!
    Man you really know how to depress a guy.
    Man you won't wanna get it dirty.
    Awesome job bro.
    Andrew
    Andrew.
    CIGWELD Transmig 250 Remote!!
    Weld NZ 160amp DC pulse/DC Tig / Stick
    Telwin Bimax 152 Mig
    NZIG Handi AC Stick
    NZIG Comet 3 O/A Set
    Aug 2005
    795
    Quote Originally Posted by Mike W
    The lathe is a 9X20 that was purchased to CNC for the purpose of modifying SS pins. It is going to spend it's inexpensive life making snap ring grooves!
    The drawers were cut from an aluminum composite and then folded and riveted together.
    This is the third time I have tried to post this, so I am going to post only one pic now, then I will post a few more of the drawers. This is a pic of some of the drawers waiting to be folded:
    Scott
    Aug 2005
    795
    Ok, that post went through. Let me try a few more pics of the drawers:
    I riveted the drawer faces to the drawer bodies after they were set into the slides. This way, I could micro-adjust to compensate for inaccuracies in the assemblies. The drawers are identical, the faces are identical and they all interchange pretty well, so I could have assembled the faces on the bench, but I chose to do so in place. I didn't take pictures of attaching the faces - sorry.
    Now I will try to scare up a pic of the lathe and stand....
    Oh - I used the inexpensive'est' drawer slides money can get - I had so many to buy that the ball slides would have broke the bank at $18/set. I am using the ball slides for a tool box and the drawers in the lathes stand, but these things actually work very, very well and are rated for 75 or 100 pounds per drawer! I like them. and they are pretty inexpensive - like $7/set at Lowes. I found them online for around $3/set! The chrome pull handles almost cost that much each!
    The slides can be bought from Home Depot or Lowes for about $7.75 per set - but if you are smart, you will go to http://www.ovisonline.com where you can get them for about $3 per set. I have no affiliation with these folks - they have extremely good prices - best on the net for the drawer slides. I bought the pull handles from MSC - they are 4" chrome and were about $2.30 each (I think...).
    Scott
    Last edited by MXtras; 12-01-2005 at 04:08 PM. Reason: Clarification of drawer face assembly
    Central Kali
    5,292
    Nice job on the drawers. I first thought that they were spot welded until I spotted the rivets. Do you get a discount on aluminum?
    Aug 2005
    795
    Here's a pic of the lathe and stand from maybe last week - I have since added drawers and an now working on the chip tray and other guards:
    And here's another pic of the welding area:
    By the way - I cleaned everything up to re-arrange the new cabinets and decided to take a bunch of pictures. I doubt it will stay this clean or new looking for long.
    Scott
    Central Kali
    5,292
    That is one heavy duty lathe stand. Did you level the lathe?
    Aug 2005
    795
    The lathe is just sitting there right now. There are leveling screws on the bottom of the feet - don't know if you can see that in the pics - probably not.
    I prussian blued the bottom of the lathe and scraped in the pads it is sitting on so it wouldn't get twisted when I cranked it down to the stand. The stand is 3x4x1/4" tubing - it's stout and doesn't have much flex in comparison to the narrow lathe.
    Thanks, Mike.
    Scott
    Aug 2005
    795
    Wow. I need to change the color of the lathe, don't you think? It kinda ruins the mood!
    I think I will re-paint it - I have to tear it down to make some improvements/alterarions to the saddle anyway.
    Wait until you guys see the Bridgeport....
    Scott
    Central Kali
    5,292
    I am considering buying a new Bridgeport, I don't need to retire.
    Aug 2005
    795
    Sorry - your post snuck in there - I didn't see it!
    I have had most of the material for several years - I got it when the getting was good and was able to preserve it - it has protective film on it, so it's nice and shiny when you peel it off. I have used 14 or 15 sheets so far - I am down to maybe 8 sheets left - this is of the 1/8". The sheets were factory defects (handling scratches, etc).
    The brushed panels are a product called Alpolic made by Mitsubishi - it is an aluminum composite. It is typically used on gas station canopies and store fronts and is very popular because of it's lightweight, ease of fabrication and because of the fact that it is pre-finished and extremely durable.
    Scott
