Results 1 to 15 of 18
    Houston, Texas
    3,685
    Bargain at Lowe's
    I had to swap out a defective pump for my wife's fountain at Lowe's, and I always looks at the bargain table. I found 5-6 packs of DeWalt 4-1/2x1/4" grinding wheels for $3.00/pack.
    Albuquerque, NM
    4,986
    My wife is dragging my there in a few minutes to get a new patio door drape, I will see if can get a deal like that, with my luck they will charge me double.
    Regards, George
    Weldman1223 Guest
    ill be down there tomarrow
    i'll have to check that out as well
    allready have tons of grinding wheels but you can never have too many, right?
    Chicago
    150
    Lowes also has an autodarkening helmet (one of those with the narrow strip lens about an inch high) on clearance for around $50.
    Dec 2004
    hattiesburg, ms
    83
    Quote Originally Posted by Weldman1223
    Moody, why do you keep changing your name???
    Jan 2005
    Troy, NY
    285
    Quote Originally Posted by yardman1
    Also stop spending time keeping the shelves clean and burn some metal.
    LOL
    Weldman1223 Guest
    its raining out today so no welding
    also, i would be at the scrap yard but my dad took my brother down to a college in Boston to see and i have no idea where this scrap yard is
    without an address my GPS is useless and to top it all off im "directionally challenged"
    maby next week
    why did i change my name?...............................to mess with hank i dont know
    i just felt like changing it now you cant call me mysery man, try to make a title with weldman1223...
    Jan 2005
    Mid-West
    693
    Exclamation
    Lets see ........... What steps does it take weldman to finish a project ? 1,2,2,3,4,4,5,5,5,5,5,6, awe never mind we'll just start that project over. 1,1,2,2,,2,2,3,4,4. LOL Couldnt help it moody. you asked !
    Millermatic 210 "Big Blue"
    VICTOR SUPERRANGE
    OPTREL UVEX SATELLITE
    Miller SPECTRUM 625
    Pumpkinhead
    Weldman1223 Guest
    message too short........
    Nov 2004
    Quitman, AR
    557
    That is so organized, its almost scarry.
    Do you collect Hess Fire trucks?
    Weldman1223 Guest
    Quote Originally Posted by RickSidebottom
    you should have seen it before i cleaned it out, could not fit another item in there
    yep
    got every Hess truck with the boxes, family gets them for me for x-mas every year.
    that year (1989) i got 2 and lost the box for one
    the first one i got is from 1984.
    Mar 2005
    Westchester county, N.Y.
    2,177
    Speaking of bargains, i just had a friendly conversation with the owner of the local hardware store. Problem: $1.99 for a 1/2" EMT connector (set screw). They're .16 each at the supply house!
    Bakery Mechanic
    Licensed Electrician
    *****Heineken*****
    Oct 2005
    290
    hey weldman, i guess imnot theonly one who bought that bernzomatic oxy/mapp setup. That was my firts welder ever
    Weldman1223 Guest
    Quote Originally Posted by clintonwelding1
    yea i was hoping it would work a little better but its good for small cutting and it works great for brazing
    the only thing i dont like it that it eats up those oxygen tanks really fast
    in cutting it will last 8-12 minutes
    they say once you start the puddle in the cut that you can turn off the fuel as the oxygen is the only thing needed to cut.
    i need to upgrade to an O/A setup...
    Oct 2005
    290
    i recently got the o/a from my dads freind.(its on peremennt lend ) I hated those little oxygen tanks. everytime i had to buy then i bought like 5 or 6.Its great for real small stuff though.
