This is a coffee table I made over a year ago, it was my first welding project. I believe the wood was walnut laminate. The the table top and shelf are surrounded with steel angle (welded then ground shiney). The legs are capped in aluminum channel. It's hard to tell but the top and shelf have beveled edges.
What did I learn? Don't use water based clear coat on freshly ground metal. It will eventually oxidize which is what I was trying to avoid in the first place.An easy fix.
An easy fix.
