this is my new (made from old) welding table
HH 135
Hobart Champion 10000
Milwalkee tool free chop saw
Kubota DT 3000
1970 Lincoln Crackerbox
You live and learn. Or you don't live long.- Lazarus Long (Robert Heinlein)
here's a few more pics
it even turned out level!!
HH 135
Kubota DT 3000
Looks like one heck of a table you're making there! What are you gonna use to move it about?
L3000 DT KubotaOriginally Posted by patrickmcveigh
HH 135
Kubota DT 3000
Holy cow I thought my table was heavy duty.
http://www.irontoart.com/shop_stuff/shopstuff004.jpg
What do you weld on that beast. Locomotives lol![]()
Doug Arthurs
Kent Bridge Ontario
Well my dad always said that I was one of the few people he knew that could tear up an anvil, so I thought I would just try to start out ahead of the game. Also I'm tired of light tables that won't stay flat and square.
HH 135
Kubota DT 3000
How did you cut your girders? Torch?
cut everything with a Milwalkee chop sawOriginally Posted by tonyclifton
HH 135
Kubota DT 3000
You may want to have that level checked. In my personal experience, having something like your table that shows level is usually an indication of the level being bunged up.Originally Posted by gagiii
Anyway, great looking table. Now I have table AND tractor envy.
got any pics of the wooden table in the background of table #5 photo?????
And a chop saw? What size saw?
it's a 14" chop sawOriginally Posted by tonyclifton
I built that wooden table out of pressure treated 4x4 & 2x4. It's all put together with mortice & tenons. The only screws in it are in the top. I cut a piece of outdoor grade plywood in half, screwed half of it to the frame, then turned the table over and glued and screwed the other half on. Before I got the iron frame that the I-beam is on now, I had it clamped to that table so the top is pretty well messed up now but it is still very functional
I'll try to get home in time to take some picks this evening.
HH 135
Kubota DT 3000
I had to go see a lame horse about 45 miles away and it's now to dark but I'll try to get you some pics of my wooden table and chop saw tomorrowOriginally Posted by tonyclifton
HH 135
Kubota DT 3000
then I've got 3 levels that are bad. used that one in the pics because I thought the bubble showed up th bestOriginally Posted by kyoders
HH 135
Kubota DT 3000
That is one serious table you have. I would like to see the shop that it is going into. Nice work.
MM 175
Miller M-225P A.C. Arc Welder (1966)
Miller Big Window Elite A/D hood
Victor O/A Torch
Milwaukee 8" metal cutting saw
The top looks "level" but i hope the ground its sitting on is also level. I know some one that did that on there back deck , made the top all level and when it got moved to where he wanted it the table was not level anymore because the deck he made it on was not level. food for thought.Originally Posted by gagiii
Millermatic 210 "Big Blue"VICTOR SUPERRANGE
OPTREL UVEX SATELLITE
Miller SPECTRUM 625
"remember, spark production is not welding,
a nice shiny cold bead, piled high, that i can knock off with a banana does not make you a weldor."
Pumpkinhead
