Results 1 to 15 of 15
    Jun 2005
    55
    exhaust pipe welding tech!
    what amperage and kind of rod would be best for welding on an exhaust on a truck?
    Sep 2003
    Clark County, NV
    5,078
    Are you talking about butt welding tubes, or slip-fit joints, or hangers, or all of the above? Since you mention both amperage and rod, you have either a Stick or TIG in mind.
    Our answers are easier (and shorter) when you provide a little more info in the question.
    Jun 2005
    55
    slip fit pipes. one in the other. stick weld is what i had in mind.
    but i might have to butt weld up at the header.
    Apr 2005
    Indiana
    207
    How thick is the pipe?
    Lincoln 225AC
    Millermatic 135
    Firepower Oxy/Acy Torch
    Central Kali
    5,292
    I would use mig, oxy/act, or a clamp.
    Jun 2005
    55
    i dont have a mig. just common exhaust pipe. probably 1 16th. what is common stock pipe? 1 16th?
    Apr 2005
    Indiana
    207
    About that. Go with a 5/64 or 3/32 6011. If you have DC use it to weld that. Also if your running DC use a 6010 in either of the two sizes I mentioned. If 5/64 isnt available get a 3/32 rod. Run your welder at 40 to 50 amps. It may be a little hot so you'll have to start and stop to keep from blowing tons of holes in the pipe.
    Lincoln 225AC
    Millermatic 135
    Apr 2005
    Indiana
    207
    On an added note you might want to get some scrap of the pipe your afixin to weld. Practice on it before you weld the final product.
    Let us know how it turned out.
    -Ryan
    Lincoln 225AC
    Millermatic 135
    Jun 2005
    55
    thanks buddy!!!!
    Apr 2005
    Indiana
    207
    No problem
    Lincoln 225AC
    Millermatic 135
    Feb 2004
    Bulverde, tx.
    3,178
    Ryan hit the high points very well. The only thing I would add is run straight polarity on DC. It will help with blow thru.
    Don
    Go Spurs Go!!!!!!
    Jun 2005
    55
    would straight polarity be pos or neg.
    Feb 2004
    Austin TX
    4,861
    DC straight polarity is electrode negative. Just think of the minus symbol for negative as a "straight" line.
    Trailblazer 302 * Millermatic 212 * Syncrowave 180SD * X-Treme 12VS Feeder * Spoolmate 3035
    Thermal Dynamics Cutmaster 52 Plasma * Lincoln 175 MIG
    Victor Superrange II * Victor Journeyman
    Hobart HH 125EZ
    Feb 2004
    Bulverde, tx.
    3,178
    Sorry, old school terms. Shoulda said DCEN.
    Don
    Go Spurs Go!!!!!!
    Jul 2003
    Michigan
    479
    Quote Originally Posted by jeff in west vi
    Myself, I would use a 3/32 6013 rod and run it downhill. The 6013 is a much softer arc then the 6010/6011 type rods. It doesn't have the aggressive dig characteristics and is designed for thin materials. Amperage is a bit of a guess but I would start out at someplace around 80-85 range.
    BTW if you are welding it on the truck, be sure to ground to the pipe and not the frame of the truck
