Results 1 to 15 of 20
    Jul 2005
    Fort McCoy, FL
    196
    Harbor Freight Industrial Cut-Off Saw
    Does anyone have any experience or knowledge of HF tools - quality, repairs, etc.?
    They have their industrial cut-off saw on sale for $99.99 (in-store) and I was wondering if it was any good for a DIY?
    Also, how are their air tools - grinder and die cutter?
    Thanks!
    Central Kali
    5,292
    It is kind of like going to Vegas, sometimes you win, sometimes you don't.
    535
    Well put mike.
    Its even more like vegas in that, at the end of the day, the house is gunna come out on top.
    I dont think there is one thing with a harbor frieght brand name that is made in USA in htat store. Everything comes from chine, taiwan, and aprantly india too. I have never really made a big purchase from them because of this.
    It would probably be good for the occasional DIY use like you mentioned, but you will want to stick with a name brand item id say if you are lookin for something of good quality.
    JIm
    Speedglas 9100x
    Is this the 7-1/4" circular dry-cut saw or the 14" abraisive saw you're talking about?
    A lot of guys have the 14" chop saw, and like it OK. It's kinda flimsy, but does the job, I guess.
    The 7-1/4" is still an unknown. Nobody has posted on it yet that I know of. Be aware that that type of saw from a reputable manufacturer costs anywhere from $290 to $500, dpending. I wouldn't expect too much from it.
    Bakersfield, CA
    648
    I have bought three cutoff saws from HF - all the cheapo models. The first lasted through about 25 blades before I gave it to one of my sons, who is still using and abusing it. The other two are a few months old, one set for 45 and the other for 90 degrees. Both work fine.
    You have to understand the limitations and purpose of these saws. They WILL flex if overloaded or improperly supported. If you can place the saw on a good flat surface and support the work so it doesn't tweak the saw, they will produce a cut as good as a $200 saw. Put ANY saw on a warped surface, clamp the last foot of a 20' piece of 3" channel in it and let the other 19' hang, and you'll get a bad cut.
    Is a $200 saw better than a $50 saw? Maybe - but not always. Sometimes good enough really IS good enough! As an active hobby weldor, I look for the best value. I want the best price on a tool that will do what I need it to do for as long as I need it to do it. If I thought the $200 saw would perforn significantly better or last significantly longer IN MY APPLICATION, I'd buy it. Kinda like buying a $20 25' tape measure - the chop saw tears it up just like the $3 HF one!
    On the other hand, I was going to buy a Bluestar - ended up with a Bobcat 250 for $650 more. It was worth it. But if HF sold a knockoff of the Bobcat for $750, the choice would have been harder!
    Trent
    Building my wife's fortune - one machine at a time!
    Bobcat 250, MM210 w/3545 spoolgun, HH135, Miller Dialarc 250 AC/DC w/HF251, Red AC/DC tombstone, Victor SRII
    Bakersfield, CA
    648
    Didn't answer all your ?s - never had to have one repaired (and wouldn't - I'd just buy another!).
    Air tools - I have a riviter and a die grinder. Both are satisfactory, but don't see a lot of use. I need a bigger compressor to run the die grinder much.
    Trent
    535
    Oh and as far as air tools. The cheaper the tool, the more air it will need Take a look at Ingersoll rand die grinders. Thier $100+ ergonomin die grinder has the sam hp and speed ratings as their cheaper models, but uses less air at max load. More efficient motors. So, if you are going to be using it often, maybe think about the money you will savbe in electricity as well as wear and tear on your compressor by buying a higher quality tool.
    Jim
    Speedglas 9100x
    Jul 2005
    Fort McCoy, FL
    196
    HF 14" Cut-Off Saw
    Yes Hank it's what they call '14" Industrial Cut-Off Saw' (abrasive)...
    Yes Trent, I know about properly supporting and clamping the stock when cutting, thanks for the info -
    Trent, why do you have two saws each set at different angles - 90 and 45, is it for convenience or are they difficult to change the miter cut angle?
    Thank to all for the input...
    Bakersfield, CA
    648
    It's easy to get them close, but to get them right requires a square and some trial-and-error. At $45 each, it's far easier and faster to leave them set. Next time they go on salem I might get a third one for "specials" - but probably not. I don't use them as much since I got the Jet bandsaw.
    Trent
    Clark County, NV
    5,078
    Quote Originally Posted by jer29_11_13
    I do the same thing. I keep the carbide dry saw at 90 degrees, and do most of the miters on the chop saw to save the time moving the clamps around.
    Bakersfield, CA
    648
    Trent
    May 2004
    Centralia, WA
    30
    Both my die grinders (straight & 90) and my air hammer are HF. No problems yet and I run them pretty hard. Lately I've been removing lots of factory rivets from my 55 Ford frame. In the interest of disclosure though the spring on my $9.99 air hammer broke a few days ago, but a $3.99 replacement spring at Sears fit perfect.
    Ron
    Los Angeles
    5,476
    I have the Dewalt and love it. Changing to 45deg cuts is a snap until you have used the saw a very long time and the adjusting bar gets worn down.
    http://www.sears.com/sr/javasr/produ...id=00923471000
    Yes it's a 100.00 more but I think it's worth it and right now Sears will give you a 25.00 Gift card.
    MM252
    MM211
    SO 2020 Bender
    Los Angeles
    5,476
    Trent,
    Holy crap 59.99 on sale at HF.
    Yeah buy 2!!!!!
    MM252
    MM211
    SO 2020 Bender
    Bakersfield, CA
    648
    Quote Originally Posted by Broccoli1
    Trent,
    Yeah buy 2!!!!!
    I'm on their email list so I keep getting coupons good for $5 off a $50 purchase or $10 off $100....
    Trent
