I am looking for a ballast resistor for a Hobart BetaMig 251. It's Hobart part number #204873. It's a ring shaped ballast resistor that goe around the fan. Anybody?
Hi Tom, do you know the ohms value and the wattage? Resistors are easy to find substitutes for. What is it's purpose? My Beta-mig 200 has a 100 ohm, 10 watt resistor across the capacitor bank to discharge them.
No, I have a drawing but no technical specs on it yet. Still trying to get that.....
to look up in the Miller Service CD. They list the Beta Mig in 2 different files. What is the ser #? Neither file shows the part # as a seperate item and the part search did not list it. May have to call Miller to find it( Hobart). 800 558 3517 Post the ser num and I will try a old Hobart disc I have.![]()
Frank
XMT 300CC/CV (yes it still works)
Bobcat 225, Hobart Hefty CC/CV wire feeder, Profax spool gun,Victor & Smith O/A, Lincoln Tombstone(sold), Airco HF box (old Miller) MM175, IR 4KW gen set,all paid for, all work. My newest addition MM130 salvaged from a Kitrina flood area. Cleaned up and works great. . Just added a Miller Thunderbolt AC/DC, total cost to repair both less than $200.00, they both work great...another Katrina cast off.
Frank,
OK, It's a Hobart BetaMig 251 Serial# 196WS04248 Spec # 500219-001
This is a strip of stainless steel (Alkrothal 720) .046 thick and 36" long with different attachment points on the strip that connect to the P pack to control the arc..... So it would be a couple of ballast resistors if I can figure out what the ohms and wattage are at the different attachment points...![]()
I could not find a listing as such for your machine. Call the Good Ole Boys at Hobart/Miller. Is the part broken/missing????? Does it have a number on it???? Maby cross it over by manufactures num and not the Hobert num!!!!!![]()
Frank,
I have called Miller to see if their is an identical part in any of their machines. The part itself is beyond repair. It has burned through so a new piece is needed........ I would think the part should be available somewhere. Scrapping this machine over a strip of steel just pisses me off.
