Results 1 to 11 of 11
    3,341
    Dan, is this what you were wondering about the passport?
    Here is a weld with C-3 on .250 HR steel.
    The wire feed was at #67 and the voltage was maxed. It was .030 wire.
    Central Kali
    5,292
    That looks good Brand X, how many amps do you think it was running at?
    3,341
    Quote Originally Posted by Mike W
    Lets put it this way, with no meters to measure it would be a real guess.
    It sure does not want to go much higher on the wirefeed speed without
    getting bigger drops. It's a low level spray but a nice one.
    Northern Nevada
    740
    Liking that C-3 (aka stainmix) are we now
    3,341
    Quote Originally Posted by Planet X
    Yes,
    because I have have pulse now!!!!
    5,208
    Scott, I figured it was going to have some level of Spray transfer capability with the .030. I suspect it would be a safe bet to assume that you could have gotten more out of it yet with 98/2 oxy. If i had a second amp meter, i d send it to you, so we could get an idea of the unit potential. I suspect though, that you'll never really use this unit to spray arc with. After all, it was honestly designed to short arc .030 with CO2. This unit is definitely a step above the 175 amp units on its 230V side. It also looks like it will stomp all the 135/140 amp units in top end performance on its 120V side.
    3,341
    After using a Hobart 140 last month, the passport surpasses the 120 volt machines by way more of a margin then it does the small 230 volt machines (running on 230 volts that is). It's really is solid 120 volt machine!!
    Northern Nevada
    740
    Quote Originally Posted by Brand X
    Yes,
    This is true. Why dont you give her a go on some thin sheetmetal, and see how low on the volt spectrum the Passport can go
    3,341
    I was talking C-3 pulse with the Esab.
    The passport fires down low but it's just not clean like a good rec. transformer or even a inverter like the Thermal-arcs on .030 or the esab with any wire. The Lincoln Powermig 300 semi inverter(chopper) was way better too. I still have no problem sticking body work type stuff with the passport, only that I prefer other machines in that area. When I turn it up, I like it a whole bunch.
    Northern Nevada
    740
    Oh yeah, figured you were refering to that yellow 'ultimate short arc' + almost everything else machine of yours.
    You still got that stainless scrap connection, if you get some time knock some beads out on stainless with the c-3. I never have got around to messing with that metal, even though that was the main reason I picked up the mix in the first place. Ha,anyway just curious how she compares to your tri-mix'es you've used for stainless mig welding.
    Thats a good looking pass by the way, Lincolns lucky I have no $ for another welder right know, because I could've used that Miller passport for a couple small offsite projects where welding would have been a nice option.
    3,341
    I Oh yeah, figured you were refering to that yellow 'ultimate short arc' + almost everything else machine of yours.
    I been through a few of them and that yellow one keeps raising the bar!!!
    In some ways it's pretty similar to a 300 powermig. Lets just say it's
    closer to that type of arc then a MM350P type of arc.
    I did try a little pulse ss with C3 but I had the pulse settings in the wrong
    wire size position. The weld bead in the short-arc was not quite as shiny
    as the tri-mix. only ran about one bead and did not mess with it much.
    I will chop up some coupons tomorrow and see what happens. I did
    find out I really like the Avesta gas shielded 316L, .045 flux-core
    about as well as anything. No fancy gas (75/25) or power supply
    needed. It's like squeezing a tube of toothpaste in how it lays out.
