Results 1 to 10 of 10
    Jun 2005
    2
    Mig Weld Cast Iron
    Hi guys,
    Never welded before, will be buying a welder this week. MY question is can I mig weld cast iron to mild steel or will I need to buy a stick welder. The cast I will be using is for ornamention iron.
    Monk Debrunsky
    Mar 2005
    Westchester county, N.Y.
    2,177
    Mig is probably the least desirable method for castiron. Stick or O/A. Burn some coals in an open pit for pre and post heat. NI99 rod is good or i like a silicon brazing rod.
    Bakery Mechanic
    Licensed Electrician
    *****Heineken*****
    Aug 2004
    Greenfield Center, New York
    459
    Cast Iron
    Are you sure it's cast iron and not cast steel? IF you're talking finials and small decorations tack welding would be OK. If you're talking tubs, sinks and engine blocks NO.
    HH135
    Victor 310, J-28 Torch Setup
    Thermal Arc 190S
    Thermal Dynamics Cutmaster 51 Plasma
    Andy's Place
    Midwest
    519
    If you are working with cast iron, use SMAW. I just did a repair, pre-heated the part, welded it, post heated the part, pre-heated a container of sand and burried it in the sand. No problem. I did one in the past without any pre or post heat, and it cracked along side the weld. Read up on the process before you try it, save yourself some headaches. On the other hand, you could get a big O/A setup and do it all.
    Supersized Chocolate Lab with gas leak!
    Mar 2005
    2,177
    Maybe someone has that cast iron welding link......locknstitch?
    Bakery Mechanic
    *****Heineken*****
    Central Kali
    5,292
    Austin TX
    4,861
    You guys are getting spun out with the rocket science here. If as he said it's ornamental work, such as welding picket castings and finials to mild steel pickets, then yes - MIG will work fine. It's done every single day.
    Hobart HH 125EZ
    Clark County, NV
    5,078
    I'm with Zrexxer. Sounds like this is cast finials. I've MIGged every one since I've owned a MIG. All they do is sit there; that's all they do... Use the same solid wire or flux-cored that you built the bloody gate with. Unless you plan to hinge the thing by the finials, you'll be fine.
    Jun 2005
    2
    Mig weld cast
    Thanks for the answers, I will be welding cast finials, seem like my Mig welder will do what I need for it to do.
    Monk
    Mar 2005
    2,177
    Guess when i hear "cast iron" i think of big heavy castings!...LOL
    Bakery Mechanic
    *****Heineken*****
