    Georgia
    260
    OT welding jobs?
    what kind of jobs are out there for welding? and what type of school would i need to go to for each of em? thanks
    Clark County, NV
    5,078
    The first question has too many answers; and you'll probably hear several dozen of them. Basically, start looking at things around you, EVERYTHING. Bridges, rifles, cars, probably even your belt buckle; you will see welded parts on lots of different things; somebody had to weld it. Plus, welders like most of us on this forum are complete shop mechanics as well; so a knowledge of all power and hand tools is almost a must.
    The second question is easier. You should start with a good stick or oxy-fuel welding class; and take both of them eventually. Try your local community college. Usually in their catalog, they will list the recommended order for the classes, sometimes even listing them as prerequisites for each other.
    Mar 2005
    Belton South Carolina
    787
    Mort, the wold is your canvas anything from decor to heavy equipment repair on to bridge building etc..... as far as schooling can't tell you much about that got mine the hard way.I'm sure there some good classes in your area around here I hear that Greenville Tech. has the best welding classes.
    Good Luck and keep on keeping on!!
    It's only a mistake if you don't learn from it!!!!! Wrenchbender
    Miller 250 Buzz
    Miller Trail Blazer 301
    Meco Weld master
    Very old smith smoke axe
    Hobart 400 DC portable
    Hobart porta feed 17 and a lot O' udder stuff
    Mar 2005
    787
    I have seen some things that posted here and it looks like you are on the right road already. Those high school classes help to set you up for more instructions the main thing is practice practice practice!!!
    Miller 250 Buzz
    Meco Weld master
    Georgia
    260
    thanks i am starting to look at colleges and ect and i wanna do something with welding for the rest of my life
