For all you buzz box owners, like me. Today, I put an amprobe on my welding cable to see how accurate that 'clock dial' amp lever really is. I was always wondering why my best welds were at a high setting. With the welder at 135amps, i was actually using 95amps. Im going to recalibrate the dial this week. If you use a wide assortment of electrodes, like me, I suggest checking your machine.
DO NOT try to recal your range sw. What you found out with your AP is that for the rod you chose, it required 95 amps to burn . Change rod size or type, lengthen or shorten your arc, voltage input variations all contribute to the amp readings. You need a calibrated load bank to be able to see this. As you change the load the output will very.
