Results 1 to 4 of 4
    9
    Migs for Engine driven
    I know this is most likely not the way to do this, but could I plug a regular shop mig welder into my Lincoln 250? Would it run from a regular outlet on the ranger? I'm not a mig welder at all, but a friend of mine was wondering if it was possible, now I know they make migs for the new engine drive's.
    Thanks!
    Will
    PRK, USA
    699
    Will,
    Definite maybe. I see lots of guys running around with small MIG welders and engine drive welders. It really depends on the size of the MIG welder. In theory, I should be able to run my 250 amp mig welder off of my 8000 watt welder. In reality, I'm not even going to try.
    How big of a MIG welder are you thinking of using?
    Jan 2005
    Toronto, On
    460
    You would certainly be able to get things to stick togather, just a question of how well! I know a lot of people who run 110 mig's off smaller generators at races with some success. Beats towing the car home!
    Millermatic 210
    Dynasty 200DX
    http://ca.geocities.com/rwsrally@rogers.com
    Bakersfield, CA
    648
    I've run a HH135 off my Bobcat with ease - could easily run a 180, probably a 210. Just make sure you set the welder/generator up as a generator. You don't want it dropping to idle.
    Trent
    Building my wife's fortune - one machine at a time!
    Bobcat 250, MM210 w/3545 spoolgun, HH135, Miller Dialarc 250 AC/DC w/HF251, Red AC/DC tombstone, Victor SRII
