Results 1 to 15 of 21
    Feb 2005
    Northern CA
    139
    diameter of c25 tanks?
    Howdy -
    I'm just getting rolling (pun not originally intended) on my cart that will hold my HH180 and Cutmaster 38... and a tank of inert gas. I currently have a 80 cu ft tank, but would like to size the tank pad for the next size up (120?) just in case I start welding more than I currently intend. I don't have easy access to tanks around here, so I'm not sure if the 120 is just taller, or is a larger diameter as well. Can anybody give me a hand?
    I LOVE all the pictures of the cart projects on here. I have a whole gallery of them now, and will pick and choose the parts I like the best for each. I'm starting with a hand truck that can roll on its back - seems to be about the right length and width, and the price was right!
    Thanks. And I promise pictures when this thing is done! I'm currently in a quandry -I need to build a welding table to make building the cart easier, but of course I need to build the cart to make building the table easier. Mostly though, I just bought the welder and the cutter so that I *could* build a cart for my welder and cutter. OK, I'll stop. Now I'm even confusing myself.
    - Darell
    HH180, Cutmaster 38, Miller Xlix Elite, TurnPro 7x12 Horiz bandsaw.
    Sep 2004
    Washington State
    316
    A 125 is 7" in diameter and 43" tall if that helps you any.
    - Tony
    Feb 2005
    Northern CA
    139
    It sure does, thanks Tony. Is 125 the next nominal size up from my 80?
    - Darell
    Cedar Rapids, IA
    1,943
    Quote Originally Posted by darelldd
    Howdy -
    Catch 22.
    Jim-bee
    Houston, Texas
    3,702
    It is in Houston. 122-125 is what I see mentioned.
    Albuquerque, NM
    4,986
    Regards, George
    Jun 2004
    sw sub chicago
    424
    here is what i did. size of the bottle doesn't matter. other than to the chain length. i have a 150cf on it now.
    97 s-10 vortech v2, fmic. a broken down 13.8 @ 97
    200dx
    sp135+
    port-a-torch
    miller big window
    other stuff
    Sep 2004
    Fairbanks, Alaska
    135
    S-10,
    Is the bottle sitting on the floor or just partially on the piece of angle iron? If so, the bottom of the bottle is rounded, how well does it sit on the angle iron?
    NorthernLights
    MillerMatic 251
    Hobart Handler 150
    Lincoln Precision TIG 185
    Darell,
    If you're gonna spend the money to upsize, go to 154CF. Only a couple of more dollars, the fill cost is the same, and the tank diameter is the same as the 80CF. Where are you shopping? Airgas prices are OK; MJB in Chico and Oroville are about the same. I buy from Hust Bros. in Marysville, but Mike takes care of me, so I pay a little more (or less, sometimes!).
    Nov 2003
    O'Fallon, MO
    899
    If I were you, I wouldn't make it "limiting" as far as what size tank you can go with. You might realize one day that you want more tank. That was my case. I'll attach some pics of a dual tray for my MM210. One tank is 140cf and the other is 330cf
    gde,
    Is that not the dual cylinder rack that comes with the MM210 package?
    I REALLY like your top mount caddy. I've found the built-in holders to be inconvenient when switching from the MIG gun to the 3035. Can you open the drive door with that in place? What sort of mounting does it have to protect the machine's surface? Don't have any expanded metal in the scrap pile, but even I can afford a litte of that stuff!
    11,293
    Damm, it looks like I am going to have to start waxxing my machines to keep up with you guys,, and get rid of the cardboard box catchall on top of mine.
    Cary,
    Here,
    Feel better?
    Feb 2005
    Northern CA
    139
    Quote Originally Posted by Sundown
    Sundown - Awesome! Just what the Dr. ordered. Looks like 7.5" will give me plenty of room to grow.
    - Darell
    Feb 2005
    Northern CA
    139
    Quote Originally Posted by SuperchargedS10
    Yeah, that's a good thought, certainly. My plan was to basically have a bumper around everything though - so the cart hits first... whatever it is I'm running into.
    - Darell
