[SIZE=4]MAXSTAR 150 STH
Best of Class - provides maxium portability and performance in the most compact TIG/Stick package in the industry. Dependability and performance all in one machine.
Portable in the shop or at the job site - at 13.7 lb the shoulder strap allows the operator to easily move from location to location.
Auto-Line™ Power Management technology circuitry automatically connects to 115 - 230 VAC, single-phase power without removing the cover to relink the power source.
Low OCV Stick returns OCV to 13 volts when machine is not in use.
Adaptive Hot Start for stick arc starts prevents electrode sticking.
Single Amperage Range allows operator to accurately set amperage on both 115 V or 230 V primary power.
Lift-Arc™ start provides TIG arc starting without the use of high frequency.
Built-in gas solenoid eliminates the need for bulky torch with a gas valve.
Thermal overload protection with indicator lights helps prevent machine damage if the duty cycle is exceeded or airflow is blocked.
HF (High Frequency) start for non-contact TIG arc starts (STH model only).
Built-in pulsing -select from four fixed-pulse frequencies (STH model only).
Fan-On-Demand™
Internal power source cooling system that only works when needed, keeping internal components cleaner.
Lift-Arc™
Simply touch the tungsten to the work piece…lift…and the arc is initiated instantly and automatically without the use of high frequency.
Wind Tunnel Technology™
Internal air flow that protects electrical components and PC boards from dirt, dust, debris... greatly improving reliability.
LVC™ Line Voltage Compensation
Keeps output of the power source constant regardless of fluctuation in input power ± 10%.
Adaptive Hot Start™ for Stick
Automatically increases output amperage at the start of a weld should the start require it and prevents the electrode from sticking and creating an inclusion.
Low OCV Stick
A built-in circuit that reduces the open-circuit voltage (OCV) to 13 volts when the welding power source is not in use, therefore eliminating the need for add-on voltage reducers.
Automatically conects the machine to a broad range of primary single- and three-phase, 50 and 60 Hz input voltages without manually linking. Also compensates for voltage spikes and drops within the entire range. Delivering consistent output - All done without removing the covers to relink.
TIG (GTAW)
Pulsed TIG (GTAW-P)
Stick (SMAW)
Input Power
Requires 1- Phase Power
Rated Output
Stick: 70 A at 22.8 VDC, 115 VAC
TIG: 100 A at 14.0 VDC, 115 VAC
Stick: 100A at 24.0 VDC, 230 VAC
TIG: 100A at 14.0 VDC, 230 VAC
100% Duty Cycle
Output Power Range
TIG: 5 - 150 A, 115 VAC
Stick: 20 - 100 A , 115 VAC
TIG: 5 - 150 A, 230 VAC
Stick: 20 - 150 A , 230 VAC
Net Weight
13.7 lb (6.2 kg)
STH:TIG/Stick package. When the job demands greater control the STH provides HF start, and built-in pulsing allowing selection of four fixed-pulse frequencies.
Maxstar includes all item below brand new
DB1712RDI25 TIG torch w/adapter
Protective carrying case
Gas hose and regulator
Power source with cord
10 ft (3 m) work clamp
13 ft (4m) Stick electrode holder
Shoulder strap
Extra 25' diamond back tig torch Brand new like everything else
I am selling this so i can have funds to buy a millermatic 251
The Price $1,180.00 This includes everything Brand new and ready to use
If you have any questions you can email me at Syncrowave180sd2@aol.com
i will be glad to respond to all questions asked.
If you want to buy this I will take money order or cash
I will ship it for free.
