I just finally joined after lurking around the message board for a moth or so. I wanted to learn how to Tig so after reading all the great posts about the TA 185 I decided to give it a try. I am a little confused on what Tig torches will work with this welder. Do you have to use the ones that have the separate gas line or can you used a torch that has the gas line integrated with the power cable? I am also wanted to get a hand control for the TA 185. Do you have to order the hand controls specifically for the Thermal Arc or are there universal ones that will work. I am looking at CK and Weldcraft flex head torches do you guys have any opinions on those torches?![]()
Thanks Greg Callahan
