Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Thread: Press brake
    Sep 2004
    Salt Lake City, Utah
    25
    Press brake
    I made this out of crap I had laying around. It will accept a 10" wide piece of metal, and probably bend 1/4" thick at that width. I mainly built it to bend 3/16" steel for control arm mounts and other bracketry.
    Feb 2005
    Paris,Texas
    40
    Thumbs up
    Hickey ,
    That is a really nice press break! Good job!
    [SIGPIC][/SIGPIC]TruckinMach1
    Miller Bobcat 250
    Miller DialArc 250
    MM 210 w/3035 Spoolgun
    Spectrum 625 Plasma
    Victor & Harris O/A
    Cedar Rapids, IA
    1,943
    I like the design. Nice job. Those welds look great. Could you take some close-up shots?
    Jim-bee
    Sep 2004
    25
    Quote Originally Posted by James D. Clark
    That's a pic of the good side. The bird poop is on the other side.
    What would you like a close up of?
    Sep 2004
    25
    Here is a pic of the lower die.
    Cedar Rapids, IA
    1,943
    Quote Originally Posted by Hickey
    I've walked bare-foot in the chicken house. I can take it. Both sides if there is something that a picture will help explain. Looks like a project that will have a lot of interest. Could it be made to take removable punch and die for various thicknesses?
    Jim-bee
    moody Guest
    can you make a parts list for that?
    i would like to make one
    moody Guest
    is that upper die sharpened at all or just left as is?
    Sep 2004
    25
    The upper die is removeable, could be replaced with a more rounded leading edge to give a more gradual bend on the inside. The lower die is made of two pieces of 1" square stock that are sitting on the corner/point of the square so that they make a V between them. the frame is made from 2x4 3/16" tube and some 1/4" plate for the bottom plate. the upper die is made of 1/2" flat bar that is 2" wide. I beveled the leading press edge with a flap wheel. There are some guides on the frame toward the bottom that keep the lower die centered while it travels up and down. They are made of 3/8" round stock.
    Sep 2004
    25
    Here is the only pice I have bent with it so far.
    moody Guest
    how is the upper die removeable?
    looks like the jack would have to come out to remove the upper die
    moody Guest
    it does do a nice job
    Sep 2004
    25
    Quote Originally Posted by moody
    Correct. Remove springs, remove jack, and then the die will slide upward and come out.
    Sep 2004
    25
    Okay, I went out and bent some 1/8" flat bar, about 2" wide.
    First pic is after the first bend.
    second pic is with the bender compressed on the second bend.
    third pic is the finished metal.
    I still need to finish beveling the leading edge, it still has about a 3/16" flat edge to it right now.
    Jun 2004
    Sadorus Il
    976
    DETAILS, WE NEED MORE DETAILS!!!
    So we ( i ) can COPY your press break!!
    HH180
    Cutmaster 51
