Hello, I am having Intermittent problems with the high freq on start mode,
the high freq works properly in the continuous mode. according to the
wiring schematic the CR1 relay should energize to start the high freq, I
have opened the machine and checked the voltage at the relay coil when I hit
the torch trigger and have 37 volts DC at the coil. Does anyone know what
the coil voltage should be ? could the problem be the variable resistor R3.
Any help will be greatly appreciated
