Can anyone fill me in on the differences here?
Also, am looking for good on-line welding guides - have a few now, but can't get enough!!!
thanks
thanks
A given machine might weld from 20-210 amps, but it is rated at maybe 60% duty cycle @160 amps. At maximum output the duty cycle might drop to 20%. In this case the machine would put out an honest 210 amps, but only for 2 minutes out of q10 where as it will put out 160 amps for 6 minutes out of 10. Some machines have a 20% duty cycle at all ranges and some are as high as 100% at lower output.
Thanks for the clarification, Cope.
oldbab, there is some good info here;![]()
http://www.esabna.com/EUWeb/MIG_handbook/592mig4_13.htm
Rated Output
This rating is done in accordance to NEMA standards to make any comparisons between machines / brands fair.
This rating is made up of 3 numbers ( more if you count ambient conditions like temp )
1. Rated output . This is generally the amps that a machine can provide into load bank ( kinda like a dyno for welders ) at a given VOLTAGE and DUTY CYCLE
2. Volts at rated output. This is the tricky one. A manufacturer could choose to do this test at a voltage of 26. Another would do it at 28 volts . All things equal ( rated output and duty cycle ) the machine whose rating was done at 28 volts has slightly more power
This is important depending on process being used. For example if you are burning a self shieled flat position wire such as E70T-4 ( Fabshield 4 or NS-3M ) these wires run at typically 30+ volts. So when you look at the rating of an engine drive such as a Traiblazer 302 where its 300 amps at 25 arc volts , chances are you won't be able to squeeze the 300 amps 100% duty cycle rating when using this particular wire
3. Duty Cycle. - much has been discussed on this. The key points to remember :
- If you are comparing machines, should try to use the same DC rating
- Duty cycle can be quoted for different outputs. For example, a Deltaweld 302 is rated at 300 amps 100%DC but about 380amps at 60% duty cycle. You can see this chart in their brochure
- Manufacturers generally use 100% DC rating in their brochures for industrial style machines. They tend to use 60 and / or 40 % for the light industrial and anywhere from 20 to 30% for their smaller MIGs
- Generally speaking because a machine has a *** amp rating at 40% duty cycle does NOT mean the machine is not capable of operating at higher than 40% duty cycle. It can, but obviously at a lower than *** amp rating
Conclusion : Rated output is the amp rating of a welder at a given volts and duty cycle . This is used for comparisons are choosing welders
__________________________________________________ _______________
Output Range
Output range is the min to max amps a welder can output . This CANNOT be predicted from the rated output. Rated output has actually little to do with the max output of a welder
The things that determine max output
1. Design of the transformer / switching devices in the machine
2. Design criteria of the welder
Max output generally determined at design stage and limited by circuit boards
3. Software . Newer welders such as the inveters or choppers have their output limited by software
It is often incorrect to assume that a machine with a higher rated output has higher output range
For example, a Ranger 305 has a rating of 300 amps @100% DC . Max amps out of this machine is about 305 amps . A Classic 300D has a rating of 300 amps at 60% and 250 amps at 100% DC . One would assume the Ranger has more power.............BUT in reality the Classic 300 is capable of outputting over 400 amps ! and therefore has a higher output range
Go figure !
Where you see a large difference between rated output and max output are generator welders ( the "grey coloured " Lincolns such as the Classics or SAE's ) , inverter pulse MIG machines ( need very high peak currents for pulse GMAW ), or large transformer style industrial power supplies ( the big 600 amp and above machines ) that are used for carbon arc gouging
Hope this doens't confuse you more !
I'll have to reread a bit,. Thanks for the info.
