    Jan 2005
    What size Circuit Breaker?
    What size Circuitbreaker is reccomended for a 235 amp ac stick welder?
    Also what size wire for circuit?
    OLddog
    11,282
    50 amp breaker.
    Cedar Rapids, IA
    1,943
    A 50 amp normal breaker, 40 amp time delay and #10 wire is what is recommended for up to 250 amp welder.
    Jim-bee
    Oct 2004
    Brentwood Bay B.C.
    104
    My welder says the primary amps are 45.5 would it be ok to run it of a 50 amp breaker?
    Keep On Truckin'
    11,282
    Yes, these machines are designed to run from 50A circuits. Also we have been recommending 6 wire due to a number of factors that are listed in another thread. If it is only for a welder a number 8 is fine too as long as other types of equipment will not be used on this circuit.
