Results 1 to 4 of 4
    Dec 2004
    Spring Grove, IL
    2
    Need wire advice
    Hi, new here and new to mig welding.
    I am working on replacing some body panels on my project car and I'm not sure what wire I need to use.
    I use a Handler 135 and I'm picking up a tank of argon mix gas. What wire would be best for such an application?
    Aug 2004
    Winter Haven, Fl.
    495
    .023 is probably what you need, you can get it pretty cheap at harbor freight, 10pound spool for $14
    master of all trades, jack of none...or sumtin like that...
    Jun 2004
    Sadorus Il
    976
    .025 solid wire ER70s 6 i think is the aws #
    HH180
    Cutmaster 51
    Dec 2004
    Spring Grove, IL
    2
    Thanks.
    Here is a pic of the car in it's current state. Plan to replace the rocker panel this week, then moving on to stiffening it up and designing a roll cage.
